/var/mod/root # /etc/init.d/rc.vpnc start
Starting vpnc...modprobe: module ip_tables not found in modules.dep
modprobe: module ip_conntrack not found in modules.dep
modprobe: module iptable_filter not found in modules.dep
modprobe: module iptable_nat not found in modules.dep
modprobe: module ipt_MASQUERADE not found in modules.dep
iptables v1.4.1.1: can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
iptables v1.4.1.1: can't initialize iptables table `nat': Table does not exist (do you need to insmod?)
VPNC started in background (pid: 2669)...
done.
/var/mod/root # ifconfig
tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:158.110.123.63 P-t-P:158.110.123.63 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP ALLMULTI MULTICAST MTU:1412 Metric:1
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
TX packets:113 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:500
RX bytes:56 (56.0 B) TX bytes:6879 (6.7 KiB)
