fehler beim fritzen eines sinus w500v "not connected"
aeiou123456
16 Sep 2007
hallo,
versuche meinen sinus w500v zu fritzen. es scheint alles gut zu funktionieren, bis auf den flashvorgang selbst.
bekomme folgendes hin:
speed-to-fritz directory exists
Your settings from the last run of speed-to-fritz:
Speedporttype=W500V
OEM=avm
CONFIG_PRODUKT=Fritz_Box_DECT_W500V
ANNEX=B
Imagename=fw_C_Sinus_500_.04.27-0_Fritz_Box_DECT_W500V_38.04.71-0-sp2fr-10.01.15-r-761M-888_OEM-avm_annexB_de.image
AVM Type=7150
The following script should do this for you:
Installing or updating the latest freetz/trunk
Updating your LINUX system and installing missing tools needed for freetz
invoking 'make menuconfig'
invoking 'make'
invoking 'speed-to-freetz'
  Did you run speed-to-fritz to set up the variables in use' (y/n)?
You are starting with clean configuration, all settings made last time are removed!
# configuration written to Firmware.conf
*** End of Speed-to-fritz configuration.
*** Execute 'sp-to-fritz.sh' to build Speed-to-fritz.
Firmware configuration taken from: Firmware.conf
Speed-to-Fritz version: 15.01.10-multi
Phase 1: Download or check firmware images.
Phase 2: Unpack and extract files from images.
Extracting image files to temporary directories ...
-- Unpacking Sinus_W_500V.27.04.27.image to:
      /home/fritz/Desktop/speed-to-fritz/SPDIR
remove tichksum
splitting kernel image
Extract Filesystem ...
546 inodes (661 blocks) to write
[===============================================================|] 661/661 100%
created 385 files
created 55 directories
created 161 symlinks
created 0 devices
created 0 fifos
unpacking var.tar
-- Unpacking fritz.fon_7150.annexb.38.04.71.image to:
      /home/fritz/Desktop/speed-to-fritz/FBDIR
remove tichksum
2678 inodes (2810 blocks) to write
[=============================================================\] 2810/2810 100%
created 2281 files
created 124 directories
created 241 symlinks
created 156 devices
created 0 fifos
unpacking var.tar
Images extracted... Press 'ENTER' to continue
Verifying version of firmware images ...
-- T-Home firmware version:	.04.27-0
-- AVM    firmware version:	38.04.71-0
-- AVM     # Versioninfo:	38.04.71
-- AVM     # Checkpoint:	r14616
-- T-Home  # Kernelsize:	7798784
-- AVM     # Kernelsize:	7798784
-- T-Home Kernel version is:
-- AVM  Kernel version is: 2.6.13.1-ohio
ATTENTION! Kernel version of AVM and T-Home Firmware differ!
You can't use options like:
'Force use of t-com piglet driver' or 'Force use of T-Home fon driver.
-- T-Home  uClib version is: 0.9.26
-- AVM   uClib version is: 0.9.29
WARNING! uClib version of AVM and T-Home firmware differ!
HW Feature	Fritz_Box_DECT_W500V	Fritz_Box_7150
DECT:		detected    		detected
ISDN NT:	not detected		not detected
ISDN TE:	not detected		detected
USB Port:	not detected		1.0 detected
a/b Ports:	0 Port(s)		0 Port(s)
eth Ports:	1 Port(s)		1 Port(s)
Phase 3: Copy sources.
500/////////////////////////////////////////////////////////////////////////////
-- Removed directory: www/freenet
Phase 4: Apply changes.
-- Copy Speedport LED-configfile:
      /etc/led.conf
Fritz_Box_7150  --->   Fritz_Box_DECT_W500V
-- Matching Versions: 04.71-0 - 04.27-0
-- Move contents of OEM directory:
      move /etc/default.Fritz_Box_7150 --> /etc/default.Fritz_Box_DECT_W500V
-- Copy original T-com module:
      /lib/modules
New WEB GUI will be modified
-- Adding DECT handsets setup pages...
applying patch file /home/fritz/Desktop/speed-to-fritz/alien/patches/add_dect_de_ut8.patch
patching file fon/fonsetupdect.frm
patching file fon/dect0.frm
patching file fon/dect0.html
patching file fon/dect0.js
patching file fon/fon1dect.frm
patching file fon/fon1dect.html
patching file fon/fon1dect.js
patching file fon/foneditdect.frm
patching file fon/foneditdect.html
patching file fon/foneditdect.js
patching file fon/fonlist.html
patching file fon/fonlistdect.frm
patching file fon/fonlistdect.html
patching file fon/fonlistdect.js
patching file fon/fonsetupdect.html
patching file fon/fonsetupdect.js
applying patch file /home/fritz/Desktop/speed-to-fritz/alien/patches/add_dect_on-off_de_ut8.patch
patching file dect/setting.frm
patching file dect/setting.html
patching file dect/setting.js
patching file menus/menu2_dect.html
'#content' removed in File: dect0.js
'#content' removed in File: fonsetupdect.js
'#content' removed in File: fon1dect.js
'#content' removed in File: foneditdect.js
'#content' removed in File: fonlistdect.js
applying patch file /home/fritz/Desktop/speed-to-fritz/alien/patches/add_decthelp_de_ut8.patch
patching file help/hilfe_fon_dect.html
patching file help/hilfe_fon_dect_festnetzrufnummer.html
patching file help/hilfe_fon_dect_fon1isdn.html
patching file help/hilfe_fon_editdect.html
patching file help/hilfe_fon_fon1dect.html
patching file help/hilfe_fon_listdect.html
patching file help/hilfe_fon_setupdect.html
  -- piglet_width_running=1
  -- piglet_usb_power_bit=-1
  -- piglet_disable_test=1
  -- piglet_cs=5
  -- piglet_reset_bit=-2
  -- piglet_bitfile_offset=0x4c
  -- piglet_bitfile_write=-1
  -- piglet_bitfile_revbytes=1
-- Adjusting config parms in:
      /etc/init.d/rc.conf
-- Changing product to Fritz_Box_DECT_W500V
-- Setting 'HOSTNAME=fritz.box'
-- Change Productname to: FRITZ!Box Fon WLAN Sinus W 500V
-- Removing 'internal S0', from setup page ...
-- Removing 'external ISDN', from setup page ...
-- Removing 'USB' from setup page ...
-- Removing 'ETH 2-4', from setup page ...
      /etc/usbclass.tab
      /etc/usbdevice.tab
      /usr/share/ctlmgr/libctlusb.so
      /bin/usbhostchanged
      /sbin/eventadd
      /sbin/hotplug
      /sbin/lsusb
      /sbin/printserv
 -- Removing /usr/www/avm/html/de/menus/menu2_usb.inc
 -- Removing /usr/www/avm/html/de/home/menu2_usb.html
   -- Removing USB Symbol LED from:
      /usr/www/avm/html/de/home/home.html
      /usr/www/avm/html/de/menus/menu2_fon.html
      /usr/www/avm/html/de/menus/menu2_home.html
      /usr/www/avm/html/de/menus/menu2_konfig.html
      /usr/www/avm/html/de/menus/menu2_internet.html
      /usr/www/avm/html/de/menus/menu2_wlan.html
      /usr/www/avm/html/de/menus/menu2_system.html
      /usr/www/avm/html/de/menus/menu2_software.html
      /usr/www/avm/html/de/system/syslog.html
      /usr/www/avm/html/de/system/energy.html
      /usr/www/avm/html/de/system/energy.js
      /usr/www/avm/html/de/wlan/common.html
      /usr/www/avm/html/de/home/sitemap.html
      /usr/www/avm/html/de/fon/tamlist.html
      /usr/www/avm/html/de/home/tamedit.html
      /usr/www/avm/html/de/fon_config/fon_config_3fxi.js
      /usr/www/avm/html/de/fon_config/fon_config_3fxi.html
   -- Removing directory:
      /usr/www/avm/html/de/usb
 -- Remove some 'internal S0' Text in Files ...
      /usr/www/avm/html/de/fon_config/fon_config_Start.html
      /usr/www/avm/html/de/fon_config/fon_config_1.js
      /usr/www/avm/html/de/fon_config/fon_config_2.js
      /usr/www/avm/html/de/fon_config/fon_config_check.html
      /usr/www/avm/html/de/fon_config/fon_config_check.js
      /usr/www/avm/html/de/fon_config/fon_config_Dect_check.html
      /usr/www/avm/html/de/fon_config/fon_config_Dect_check.js
      /usr/www/avm/html/de/fon_config/fon_config_End.html
      /usr/www/avm/html/de/fon_config/fon_config_End.js
      /usr/www/avm/html/de/fon_config/fon_config_fondevices.js
      /usr/www/avm/html/de/fon_config/fon_config_IsdnSwitch.html
      /usr/www/avm/html/de/fon_config/fon_config_IsdnSwitch.js
      /usr/www/avm/html/de/fon_config/fon_config_msn.html
      /usr/www/avm/html/de/fon_config/fon_config_test.html
      /usr/www/avm/html/de/fon_config/fon_config_test.js
      /usr/www/avm/html/de/home/dect.js
      /usr/www/avm/html/de/home/fon1Dect.js
      /usr/www/avm/html/de/home/fon1isdn.html
      /usr/www/avm/html/de/home/fon1isdn.js
      /usr/www/avm/html/de/home/fon1.js
      /usr/www/avm/html/de/home/fonbuch.js
      /usr/www/avm/html/de/home/foncalls.js
      /usr/www/avm/html/de/home/fondevices.js
      /usr/www/avm/html/de/home/fondevlist.js
      /usr/www/avm/html/de/home/isdn.html
      /usr/www/avm/html/de/home/isdn.js
      /usr/www/avm/html/de/home/isdnoptionen.html
      /usr/www/avm/html/de/home/isdnoptionen.js
      /usr/www/avm/html/de/home/msn.html
      /usr/www/avm/html/de/home/msn.js
      /usr/www/avm/html/de/home/ppFonbuch.html
   -- Remove ISDN option from Festnetzmenue
   -- Removing lines from:
   -- Changing 'LAN 1' to 'LAN' in:
      /usr/www/avm/html/de/internet/internet_expert.js
      /usr/www/avm/html/de/internet/internet_expert.html
      /usr/www/avm/html/de/system/netipadr.js
-- Removing files ...
-- Bugfix for home.js
-- Adding 'Info' button and display of mod related data ...
-- Adding 'Info' icon on status page...
      /usr/www/avm/html/de/menus/menu2.html
-- Patching files:
      /usr/www/avm/html/de/home/home.js
     /usr/www/avm/html/de/help/modinfo.html
-- Added header: /usr/www/avm/html/de/images/fw_header980.gif
-- Add support menu-item...
-- Adding DSL expert pages ...
applying patch file /home/fritz/Desktop/speed-to-fritz/alien/patches/add_dsl_expert_de_ut8.patch
patching file internet/labor_dsl.frm
patching file internet/labor_dsl.html
patching file internet/labor_dsl.js
  /usr/www/avm/html/de/internet/adsl.html
  /usr/www/avm/html/de/internet/atm.html
  /usr/www/avm/html/de/internet/bits.html
  /usr/www/avm/html/de/internet/overview.html
-- Replace menu-item assistent...
-- Set Expertansicht ...
  'in file: /default.Fritz_Box_DECT_W500V/freenet/ar7.cfg
  'in file: /default.Fritz_Box_DECT_W500V/tcom/ar7.cfg
  'in file: /default.Fritz_Box_DECT_W500V/avm/ar7.cfg
-- Applying 'caller id reverse lookup' patch ...
-- Patching file:
      /usr/www/avm/html/avm_Lang/fon/foncalls.js
-- Make links...
     /usr/www/freenet
     /usr/www/tcom
-- Applying 'check signature' patch ...
-- Patching file:
      /usr/www/html/de/home/home.js ...
-- Signature removed in avm/html/de/home/home.js
-- Removing 'Tab0' from updatepage ...
      /usr/www/avm/html/de/system/update_OnClick_1.js
-- Patching install webpages ...
      patch update page (de) avm/html/tools/downgrade.html...
      patch update page (de) avm/html/tools/flash.html...
      patch update page (de) avm/html/tools/flash2.html...
      patch update page (de) avm/html/tools/update_not_signed.html...
      patch update page (de) avm/html/restart.html...
      patch update page (de) avm/html/tools/update_result.html...
 -- Patch system_status file ...
      /home/fritz/Desktop/speed-to-fritz/FBDIR/squashfs-root/usr/bin/system_status
-- OEM (Branding) set via firmware to: avm
-- my_ipaddress set via firmware to: 192.168.178.1
Phase 9: Patch install.
Path: /home/fritz/Desktop/speed-to-fritz/FBDIR
applying patch file /home/fritz/Desktop/speed-to-fritz/alien/patches/add_var-install.patch
patching file var/install
Phase 10: Pack and deliver.
Settings:
Script version               : 15.01.10-multi
Firmware for update via GUI  : fw_C_Sinus_500_.04.27-0_Fritz_Box_DECT_W500V_38.04.71-0-sp2fr-10.01.15-r-761M-888_OEM-avm_annexB_de.image
Firmware for update via FTP  : kernel.image
Output directory             : /home/fritz/Desktop/speed-to-fritz/Firmware.new
for T-Sinus model            : W500V
Branding set to              : avm
Hostname changed to          : fritz.box
Product name changed to      : 'FRITZ!Box Fon WLAN Sinus W 500V'
AVM source is                : Fritz_Box_7150
AVM source firmware mod is   : 7150
Ready for packing... Press 'ENTER' to continue...
Creating filesystem image, be patient ...
 Packing var.tar
Squashfs filesystem blocksize: 65536
Test kernel size is OK
kernel image size: 5694720 (max: 7798784, free: 2104064)
-- Approximately free time for the answering machine: 927s (15min 27s)
Adding checksum
Generation of new 'kernel.image' completed successfully!
Packing ...
Flashing firmware image /home/fritz/Desktop/speed-to-fritz/Firmware.new/kernel.image...
Network  cards set up for search active netconnections:  eth0 eth1 eth2 eth3 eth4 eth5
This list was set to default, but can be set to advance.
By invoking via menu or commandline option.
Ethernet card found on: eth4
Imagedirectory=/home/fritz/Desktop/speed-to-fritz/Firmware.new
oem: avm  Produkt: Fritz_Box_DECT_W500V  HWResvison: 101.1.1.0  Eth: eth4  IP: 192.168.178.1  jffs2size: 32  kernel_args: annex=B
All settings will be removed, because clear mtd3 and mtd4 was selected!
Press 'ENTER' to proceed!
You should now reboot your box. Waiting for box to shut down for restart ...
Box is back up again. Initiating file transfer of 'kernel.image' ...
Please be patient, it takes about one minute to erase the mtd1 partition ...
Reset environment...
Not connected.
Not connected.
Debugging on (debug=1).
Hash mark printing on (1024 bytes/hash mark).
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Waiting for box to shut down again for restart ...
If the Box is not rebooting you have to switch off / on the powerline of the box now.
Box is back up again...
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Finished transfering kernel.image to Speedport. Enjoy!
All done .... Press 'ENTER' to return to the calling shell.
linux läuft in der vm. der sinus ist frisch werksresetet und direkt per kabel angeschlossen. hat jedoch keinen internetzugang.
was seltsam ist ist, dass beim punkt
ich nach dem tatsächlichen routerneustart nichts passiert. erst wenn ich die netzwerkverbindung der vm zum pc manuell trenne und wiederherstelle
was ich auch nicht ganz verstanden habe: kann ich nach variante 2 auch einfach die firmware von avm nehmen und sie im webinterface laden? welche muss ich dann genau nehmen? das wäre ja die einfachste lösung...
hilfe
Edit Ernest015: Bildschirmausgabe in code-tags gesetzt, Doppelpost zu einem Beitrag zusammengefasst
Nein. Damit das Sinus mit der AVM-Firmware läuft, sind zusätzliche Hardware-Treiber aus der ursprünglichen originalen TCOM-Firmware erforderlich. Diese werden durch das Script mit eingebaut. Mit einer originalen AVM-Firmware läuft die Box nicht, abgesehen davon lässt sich eine originale Firmware aufgrund einer Sicherheitsabfrage bei einer bislang "ungefritzten" Box auch nicht per Weboberfläche laden.
Eine per Script erzeugte Firmware lässt sich jedoch auch über die Weboberfläche flashen, im Ordner Firmware.new ist dazu die Datei mit dem langen Dateinamen (fw_C_speedport...) vorhanden. Hier ist jedoch zu beachten, was in der Anleitung über die Verwendung des Neustart-Buttons gesagt wird, dieser darf nicht zu früh gedrückt werden.
Was jetzt die VM anbelangt, das kann verschiedene Ursachen haben: Falscher Netzwerk-Modus in der VM (Bridged/NAT) oder auch evtl. eine fest eingestellte IP-Adresse des Rechners. Das Hochladen der Firmware vom Script aus erfolgt per FTP, hier ist die Adresse in der Regel die 192.168.178.1. Steht nun der Rechner beispielsweise fest im Adressbereich der ursprünglichen Weboberfläche (192.168.2.xxx) kann die FTP-Verbindung nicht aufgebaut werden.
mfg
was ist der richtige modus in der vm?
habe die einstellungen von deinem ubuntu image nicht verändert
Normalerweise "bridged", die VM ist auch so eingestellt. Was aber noch erwähnt werden sollte: Es darf sich keine weitere Netzwerkkarte im Rechner befinden, im Bridged-Modus benutzt VMWare die erste physikalische Netzwerkkarte, die es findet. Das muss dann nicht die sein, an der die Box hängt, auch TV-Karten, DVB-Sticks oder ISDN-Karten zählen dazu. Auch ein Switch oder Hub kann Probleme bereiten.
Ist evtl. eines oder mehrere dieser Geräte im Rechner?
mfg
Edit Ernest015: Überflüssiges Vollzitat des vorangegangenen Beitrags entfernt.
hatte gestern genau das selbe Problem mit dem Sinus 500v flashen , lösung zum schluß war den sinus und pc an einem switch zu hängen dann lief das skript durch incl flashen
Probleme beim Flashen eines Speedport W503V-A
Ich habe ähnliche Probleme, nur das es bei mir scheinbar noch früher abbricht.
(siehe log)
Was ich nicht verstehe ist der IP-Kram.
Mein Rechner ist per DHCP auf IP 192.168.2.100 eingestellt worden.
Der Speedport vergibt immer nur Adressen in der 192.168er Range.
Dann ist abe wieder die Rede davon, dass der firmware-upload auf IP 192.168.178.1 laufen muss und dass das von 192.168... aus nicht möglich ist.
Wie müssen denn Rechner und Port IP-seitig konfiguriert werden?
Und was genau muss man tun, wenn das Skript auffordert "You should now reboot your box. Waiting for box to shut down for restart"?
Ich habe Strom ab-/anschalten, Reset-Knopf und per Webbrowser Werkseinstellungen herstellen ausprobiert. Alles ohne Erfolg.
Ich habe Ubuntu 10.10 native laufen, also keine VM. Es gibt nur eine Netzwerkkarte und ich habe zudem gesagt, dass er diese verwenden soll.
Auch fixe IP verwenden habe ich in den Options von speed2fritz aktiviert.
Was mache ich noch falsch?
Danke!
Not connected.
Not connected.
Not connected.
Not connected.
/bin/bash
Not connected.
/bin/bash
Not connected.
/bin/bash
Not connected.
Your PC or/and VM machine net-card is not set up correctly
Make sure only one net-card is installed or specify the proper eth0 .. eth9
within speed-to-fritz menu options, WLAN-, IDSN- or TV-cards do count as as well.
If a VM (virtual machine) is in use make sure VM is stared with administrator rights.
Right click on the VM program and select 'Start as administrator'
@jufoda,
alle AVM Boxen haben eine Art Notzugang der 3-5 sec. nach dem Einschalten unter 192.168.178.1 zu erreichen ist.
Nur hierüber kann das SP mit dem veränderten Image "bestückt" werden.
Setz bitte mal in Deinem Ubuntu eine feste IP aus dem Bereich 192.168.178.x (ausser der .1 natürlich).
Damit sollte auch das Script die Box (nach Wiedereinschalten) finden können.
Nebenbei: Diese Adresse hat nichts mit dem Zugang zum Webinterface zu tun !
Gruss
KlausBock
Hallo Klaus,
Danke für die schnelle Antwort. Werde ich probieren.
Viele Grüße,
Malte
Keine Mitglieder online.
sunburstc
