Hylafax - IAXmodem - RSPREC error/got DCN (sender abort) {E103}
[email protected]
20 Jan 2006
Hallo!
Weiß jemand wo man eine Beschreibung finden was das Logfile von Hylafax genau bedeutet?
Oder wie man den Fehler:
"RSPREC error/got DCN (sender abort) {E103}"
wegbringt?
Danke,
Hannes
Beispiel vom Logfile:
Apr 20 10:46:17.64: [ 2490]: SESSION BEGIN 000107656 +437744888
Apr 20 10:46:17.64: [ 2490]: HylaFAX (tm) Version 5.1.8
Apr 20 10:46:17.64: [ 2490]: CallID: '01234' '' '<NONE>' '077888'
Apr 20 10:46:17.64: [ 2490]: MODEM set XON/XOFF/FLUSH: input ignored, output disabled
Apr 20 10:46:17.64: [ 2490]: <-- [4:ATA\r]
Apr 20 10:46:21.36: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:21.36: [ 2490]: ANSWER: FAX CONNECTION  DEVICE '/dev/ttyIAX6'
Apr 20 10:46:21.36: [ 2490]: STATE CHANGE: ANSWERING -> RECEIVING
Apr 20 10:46:21.36: [ 2490]: RECV FAX: begin
Apr 20 10:46:21.36: [ 2490]: <-- HDLC<32:FF C0 04 B5 00 AA 12 9E 36 86 62 82 1A 04 14 2E B6 94 04 6A A6 4E CE 96 F6 76 04 AC 74 8C 74 1C>
Apr 20 10:46:21.36: [ 2490]: <-- data [32]
Apr 20 10:46:21.36: [ 2490]: <-- data [2]
Apr 20 10:46:22.28: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:22.28: [ 2490]: <-- HDLC<23:FF C0 02 A6 C6 96 6E 4E A6 CA B4 1E 86 62 B4 16 C6 A6 2E F6 66 76 92>
Apr 20 10:46:22.28: [ 2490]: <-- data [23]
Apr 20 10:46:22.28: [ 2490]: <-- data [2]
Apr 20 10:46:23.04: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:23.04: [ 2490]: <-- HDLC<13:FF C8 01 00 73 5F 23 01 FB C1 01 01 18>
Apr 20 10:46:23.04: [ 2490]: <-- data [13]
Apr 20 10:46:23.04: [ 2490]: <-- data [2]
Apr 20 10:46:23.62: [ 2490]: --> [2:OK]
Apr 20 10:46:23.62: [ 2490]: <-- [9:AT+FRH=3\r]
Apr 20 10:46:30.62: [ 2490]: --> [0:]
Apr 20 10:46:30.62: [ 2490]: MODEM <Empty line>
Apr 20 10:46:30.62: [ 2490]: MODEM TIMEOUT: waiting for v.21 carrier
Apr 20 10:46:30.62: [ 2490]: <-- data [1]
Apr 20 10:46:30.64: [ 2490]: --> [2:OK]
Apr 20 10:46:30.64: [ 2490]: <-- [9:AT+FRS=7\r]
Apr 20 10:46:30.64: [ 2490]: <-- [9:AT+FTH=3\r]
Apr 20 10:46:30.66: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:30.66: [ 2490]: <-- HDLC<32:FF C0 04 B5 00 AA 12 9E 36 86 62 82 1A 04 14 2E B6 94 04 6A A6 4E CE 96 F6 76 04 AC 74 8C 74 1C>
Apr 20 10:46:30.66: [ 2490]: <-- data [32]
Apr 20 10:46:30.66: [ 2490]: <-- data [2]
Apr 20 10:46:32.44: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:32.44: [ 2490]: <-- HDLC<23:FF C0 02 A6 C6 96 6E 4E A6 CA B4 1E 86 62 B4 16 C6 A6 2E F6 66 76 92>
Apr 20 10:46:32.44: [ 2490]: <-- data [23]
Apr 20 10:46:32.44: [ 2490]: <-- data [2]
Apr 20 10:46:33.18: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:33.18: [ 2490]: <-- HDLC<13:FF C8 01 00 73 5F 23 01 FB C1 01 01 18>
Apr 20 10:46:33.18: [ 2490]: <-- data [13]
Apr 20 10:46:33.18: [ 2490]: <-- data [2]
Apr 20 10:46:33.76: [ 2490]: --> [2:OK]
Apr 20 10:46:33.76: [ 2490]: <-- [9:AT+FRH=3\r]
Apr 20 10:46:34.72: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:36.62: [ 2490]: --> HDLC<25:FF C0 C2 0C 4C 8C 6C CC 4C 2C 4C 4C CC CC 0C 04 04 04 04 04 04 04 04 53 C1>
Apr 20 10:46:36.62: [ 2490]: --> [2:OK]
Apr 20 10:46:36.62: [ 2490]: RECV recv TSI (sender id)
Apr 20 10:46:36.62: [ 2490]: REMOTE TSI "01234"
Apr 20 10:46:36.62: [ 2490]: <-- [9:AT+FRH=3\r]
Apr 20 10:46:36.88: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:36.88: [ 2490]: --> HDLC<9:FF C8 C1 00 60 1F 22 0D DD>
Apr 20 10:46:37.20: [ 2490]: --> [2:OK]
Apr 20 10:46:37.20: [ 2490]: RECV recv DCS (command signal)
Apr 20 10:46:37.20: [ 2490]: REMOTE wants 9600 bit/s
Apr 20 10:46:37.20: [ 2490]: REMOTE wants A4 page width (215 mm)
Apr 20 10:46:37.20: [ 2490]: REMOTE wants unlimited page length
Apr 20 10:46:37.20: [ 2490]: REMOTE wants 3.85 line/mm
Apr 20 10:46:37.20: [ 2490]: REMOTE wants 2-D MMR
Apr 20 10:46:37.20: [ 2490]: REMOTE wants T.30 Annex A, 256-byte ECM
Apr 20 10:46:37.20: [ 2490]: RECV training at v.29 9600 bit/s
Apr 20 10:46:37.20: [ 2490]: MODEM set XON/XOFF/DRAIN: input ignored, output generated
Apr 20 10:46:37.20: [ 2490]: <-- [10:AT+FRM=96\r]
Apr 20 10:46:41.34: [ 2490]: --> [6:+FRH:3]
Apr 20 10:46:41.34: [ 2490]: MODEM set XON/XOFF/DRAIN: input ignored, output disabled
Apr 20 10:46:41.34: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:43.24: [ 2490]: --> HDLC<25:FF C0 C2 0C 4C 8C 6C CC 4C 2C 4C 4C CC CC 0C 04 04 04 04 04 04 04 04 53 C1>
Apr 20 10:46:43.24: [ 2490]: --> [2:OK]
Apr 20 10:46:43.24: [ 2490]: RECV recv TSI (sender id)
Apr 20 10:46:43.24: [ 2490]: REMOTE TSI "01234"
Apr 20 10:46:43.24: [ 2490]: <-- [9:AT+FRH=3\r]
Apr 20 10:46:43.50: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:43.50: [ 2490]: --> HDLC<9:FF C8 C1 00 60 1F 22 0D DD>
Apr 20 10:46:43.80: [ 2490]: --> [2:OK]
Apr 20 10:46:43.80: [ 2490]: RECV recv DCS (command signal)
Apr 20 10:46:43.80: [ 2490]: REMOTE wants 9600 bit/s
Apr 20 10:46:43.80: [ 2490]: REMOTE wants A4 page width (215 mm)
Apr 20 10:46:43.80: [ 2490]: REMOTE wants unlimited page length
Apr 20 10:46:43.80: [ 2490]: REMOTE wants 3.85 line/mm
Apr 20 10:46:43.80: [ 2490]: REMOTE wants 2-D MMR
Apr 20 10:46:43.80: [ 2490]: REMOTE wants T.30 Annex A, 256-byte ECM
Apr 20 10:46:43.80: [ 2490]: RECV training at v.29 9600 bit/s
Apr 20 10:46:43.80: [ 2490]: MODEM set XON/XOFF/DRAIN: input ignored, output generated
Apr 20 10:46:43.80: [ 2490]: <-- [10:AT+FRM=96\r]
Apr 20 10:46:47.96: [ 2490]: --> [6:+FRH:3]
Apr 20 10:46:47.96: [ 2490]: MODEM set XON/XOFF/DRAIN: input ignored, output disabled
Apr 20 10:46:47.96: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:49.86: [ 2490]: --> HDLC<25:FF C0 C2 0C 4C 8C 6C CC 4C 2C 4C 4C CC CC 0C 04 04 04 04 04 04 04 04 53 C1>
Apr 20 10:46:49.86: [ 2490]: --> [2:OK]
Apr 20 10:46:49.86: [ 2490]: RECV recv TSI (sender id)
Apr 20 10:46:49.86: [ 2490]: REMOTE TSI "01234"
Apr 20 10:46:49.86: [ 2490]: <-- [9:AT+FRH=3\r]
Apr 20 10:46:50.12: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:50.12: [ 2490]: --> HDLC<9:FF C8 C1 00 60 1F 22 0D DD>
Apr 20 10:46:50.42: [ 2490]: --> [2:OK]
Apr 20 10:46:50.42: [ 2490]: RECV recv DCS (command signal)
Apr 20 10:46:50.42: [ 2490]: REMOTE wants 9600 bit/s
Apr 20 10:46:50.42: [ 2490]: REMOTE wants A4 page width (215 mm)
Apr 20 10:46:50.42: [ 2490]: REMOTE wants unlimited page length
Apr 20 10:46:50.42: [ 2490]: REMOTE wants 3.85 line/mm
Apr 20 10:46:50.42: [ 2490]: REMOTE wants 2-D MMR
Apr 20 10:46:50.42: [ 2490]: REMOTE wants T.30 Annex A, 256-byte ECM
Apr 20 10:46:50.42: [ 2490]: RECV training at v.29 9600 bit/s
Apr 20 10:46:50.42: [ 2490]: MODEM set XON/XOFF/DRAIN: input ignored, output generated
Apr 20 10:46:50.42: [ 2490]: <-- [10:AT+FRM=96\r]
Apr 20 10:46:54.58: [ 2490]: --> [6:+FRH:3]
Apr 20 10:46:54.58: [ 2490]: MODEM set XON/XOFF/DRAIN: input ignored, output disabled
Apr 20 10:46:54.58: [ 2490]: --> [7:CONNECT]
Apr 20 10:46:55.72: [ 2490]: --> HDLC<5:FF C8 DF 59 6F>
Apr 20 10:46:55.76: [ 2490]: --> [2:OK]
Apr 20 10:46:55.76: [ 2490]: RECV recv DCN (disconnect)
Apr 20 10:46:55.76: [ 2490]: RECV FAX: RSPREC error/got DCN (sender abort) {E103}
Apr 20 10:46:55.76: [ 2490]: RECV FAX: end
Apr 20 10:46:55.76: [ 2490]: RSPREC error/got DCN (sender abort) {E103}
Apr 20 10:46:55.76: [ 2490]: SESSION END
Edit Guard-X: Bitte nächstes Mal Code Tags verwenden!
Bbj
