user@host:~/temp/freetz-trunk$ make
tar -C source -v -xzf dl/fakeroot_1.11.4.tar.gz
fakeroot-1.11.4/
fakeroot-1.11.4/build-aux/
fakeroot-1.11.4/build-aux/ltversion.m4
fakeroot-1.11.4/build-aux/ltsugar.m4
fakeroot-1.11.4/build-aux/libtool.m4
fakeroot-1.11.4/build-aux/ltoptions.m4
fakeroot-1.11.4/build-aux/lt~obsolete.m4
fakeroot-1.11.4/AUTHORS
fakeroot-1.11.4/message.h
fakeroot-1.11.4/NEWS
fakeroot-1.11.4/bootstrap
fakeroot-1.11.4/contrib/
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/MANIFEST
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/META.yml
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/README
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/Makefile.PL
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/lib/
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/lib/Fakeroot/
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/lib/Fakeroot/Stat.pm
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/t/
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/t/Fakeroot-Stat.t
fakeroot-1.11.4/contrib/Fakeroot-Stat-1.8.8/Stat.xs
fakeroot-1.11.4/configure
fakeroot-1.11.4/README
fakeroot-1.11.4/test/
fakeroot-1.11.4/test/t.chmod_dev
fakeroot-1.11.4/test/t.touchinstall
fakeroot-1.11.4/test/t.option
fakeroot-1.11.4/test/compare-tar
fakeroot-1.11.4/test/defs.in
fakeroot-1.11.4/test/t.tar
fakeroot-1.11.4/test/tartest.tar.gz.uue
fakeroot-1.11.4/test/t.mknod
fakeroot-1.11.4/test/t.no_ld_preload_link
fakeroot-1.11.4/test/t.falsereturn
fakeroot-1.11.4/test/t.truereturn
fakeroot-1.11.4/test/t.echoarg
fakeroot-1.11.4/test/Makefile.in
fakeroot-1.11.4/test/echo_arg
fakeroot-1.11.4/test/Makefile.am
fakeroot-1.11.4/simple.c
fakeroot-1.11.4/communicate.c
fakeroot-1.11.4/BUGS
fakeroot-1.11.4/config.sub
fakeroot-1.11.4/acinclude.m4
fakeroot-1.11.4/DEBUG
fakeroot-1.11.4/configure.ac
fakeroot-1.11.4/config.h.in
fakeroot-1.11.4/scripts/
fakeroot-1.11.4/scripts/fakeroot.in
fakeroot-1.11.4/scripts/instdebug
fakeroot-1.11.4/scripts/Makefile.in
fakeroot-1.11.4/scripts/Makefile.am
fakeroot-1.11.4/libfakeroot.c
fakeroot-1.11.4/.gitignore
fakeroot-1.11.4/aclocal.m4
fakeroot-1.11.4/communicate.h
fakeroot-1.11.4/ChangeLog
fakeroot-1.11.4/ltmain.sh
fakeroot-1.11.4/COPYING
fakeroot-1.11.4/wrapfunc.inp
fakeroot-1.11.4/statconv/
fakeroot-1.11.4/statconv/glibc/
fakeroot-1.11.4/statconv/glibc/linux/
fakeroot-1.11.4/statconv/glibc/linux/alpha/
fakeroot-1.11.4/statconv/glibc/linux/alpha/stats.h
fakeroot-1.11.4/config.guess
fakeroot-1.11.4/debian/
fakeroot-1.11.4/debian/fakeroot.prerm
fakeroot-1.11.4/debian/rules
fakeroot-1.11.4/debian/control
fakeroot-1.11.4/debian/copyright
fakeroot-1.11.4/debian/changelog
fakeroot-1.11.4/debian/fakeroot.postinst.in
fakeroot-1.11.4/debian/fakeroot.postrm
fakeroot-1.11.4/Makefile.in
fakeroot-1.11.4/depcomp
fakeroot-1.11.4/wrapawk
fakeroot-1.11.4/INSTALL
fakeroot-1.11.4/missing
fakeroot-1.11.4/doc/
fakeroot-1.11.4/doc/sv/
fakeroot-1.11.4/doc/sv/faked.1
fakeroot-1.11.4/doc/sv/fakeroot.1
fakeroot-1.11.4/doc/sv/Makefile.in
fakeroot-1.11.4/doc/sv/Makefile.am
fakeroot-1.11.4/doc/faked.1
fakeroot-1.11.4/doc/README.saving
fakeroot-1.11.4/doc/po4a/
fakeroot-1.11.4/doc/po4a/po4a.cfg
fakeroot-1.11.4/doc/po4a/addendum.1.nl
fakeroot-1.11.4/doc/po4a/addendum.1.es
fakeroot-1.11.4/doc/po4a/addendum.1.fr
fakeroot-1.11.4/doc/po4a/addendum.1.sv
fakeroot-1.11.4/doc/po4a/po/
fakeroot-1.11.4/doc/po4a/po/fakeroot.pot
fakeroot-1.11.4/doc/po4a/po/es.po
fakeroot-1.11.4/doc/po4a/po/nl.po
fakeroot-1.11.4/doc/po4a/po/fr.po
fakeroot-1.11.4/doc/po4a/po/sv.po
fakeroot-1.11.4/doc/fr/
fakeroot-1.11.4/doc/fr/faked.1
fakeroot-1.11.4/doc/fr/fakeroot.1
fakeroot-1.11.4/doc/fr/Makefile.in
fakeroot-1.11.4/doc/fr/Makefile.am
fakeroot-1.11.4/doc/fakeroot.1
fakeroot-1.11.4/doc/es/
fakeroot-1.11.4/doc/es/faked.1
fakeroot-1.11.4/doc/es/fakeroot.1
fakeroot-1.11.4/doc/es/Makefile.in
fakeroot-1.11.4/doc/es/Makefile.am
fakeroot-1.11.4/doc/nl/
fakeroot-1.11.4/doc/nl/faked.1
fakeroot-1.11.4/doc/nl/fakeroot.1
fakeroot-1.11.4/doc/nl/Makefile.in
fakeroot-1.11.4/doc/nl/Makefile.am
fakeroot-1.11.4/doc/Makefile.in
fakeroot-1.11.4/doc/Makefile.am
fakeroot-1.11.4/setenv.c
fakeroot-1.11.4/faked.c
fakeroot-1.11.4/Makefile.am
fakeroot-1.11.4/install-sh
sed -i "s,getopt --version,getopt --version 2>/dev/null," \
source/fakeroot-1.11.4/scripts/fakeroot.in
for i in tools/make/patches/*.fakeroot.patch; do \
tools/freetz_patch source/fakeroot-1.11.4 $i; \
done
applying patch file tools/make/patches/100-fakeroot-doc.fakeroot.patch
patching file Makefile.am
patching file Makefile.in
touch source/fakeroot-1.11.4/.unpacked
(cd source/fakeroot-1.11.4; rm -rf config.cache; \
CFLAGS="-O3 -Wall" \
CC="gcc" \
./configure \
--prefix=/usr \
--enable-shared \
--disable-nls \
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether make sets $(MAKE)... (cached) yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... ./configure: line 3733: echo: write error: Broken pipe
/bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 805306365
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking which IPC method to use... (cached) sysv
checking which database format to use... (cached) inode
checking for dlopen in -ldl... yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for unistd.h... (cached) yes
checking features.h usability... yes
checking features.h presence... yes
checking for features.h... yes
checking sys/feature_tests.h usability... no
checking sys/feature_tests.h presence... no
checking for sys/feature_tests.h... no
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for stdint.h... (cached) yes
checking for inttypes.h... (cached) yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking sys/sysmacros.h usability... yes
checking sys/sysmacros.h presence... yes
checking for sys/sysmacros.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/acl.h usability... yes
checking sys/acl.h presence... yes
checking for sys/acl.h... yes
checking for an ANSI C-conforming const... yes
checking for mode_t... yes
checking for off_t... yes
checking for size_t... yes
checking for return value and second and third argument of readlink... int, char, size_t
checking for first argument of setgroups... size_t
checking for union semun... no
checking for type of arg of __xmknod... needs *
checking for type of arg of __xmknodat... needs *
checking for type of arg of initgroups... gid_t
checking for type of arg of setreuid... gid_t
checking for type of arg of setregid... gid_t
checking for type of second arg to stat... struct stat *
checking for d_off in struct dirent... yes
checking for d_type in struct dirent... yes
checking for fchmodat... yes
checking for fchownat... yes
checking for fstatat... yes
checking for mkdirat... yes
checking for mknodat... yes
checking for openat... yes
checking for renameat... yes
checking for unlinkat... yes
checking for __xstat... yes
checking for __fxstat... yes
checking for __lxstat... yes
checking for __fxstatat... yes
checking for __xstat64... yes
checking for __fxstat64... yes
checking for __lxstat64... yes
checking for __fxstatat64... yes
checking for __xmknod... yes
checking for __xmknodat... yes
created fakerootconfig.h
checking for strdup... yes
checking for strstr... yes
checking for getresuid... yes
checking for setresuid... yes
checking for getresgid... yes
checking for setresgid... yes
checking for setfsuid... yes
checking for setfsgid... yes
checking whether setenv is declared... yes
checking whether unsetenv is declared... yes
checking for setenv... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating scripts/Makefile
config.status: creating doc/Makefile
config.status: creating doc/es/Makefile
config.status: creating doc/fr/Makefile
config.status: creating doc/nl/Makefile
config.status: creating doc/sv/Makefile
config.status: creating test/Makefile
config.status: creating test/defs
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
touch source/fakeroot-1.11.4/.configured
make -j2 -C source/fakeroot-1.11.4
make[1]: Betrete Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4'
make all-recursive
make[2]: Betrete Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4'
Making all in scripts
make[3]: Betrete Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4/scripts'
sed -e 's,[@]prefix[@],/usr,g' -e 's,[@]bindir[@],/usr/bin,g' -e 's,[@]libdir[@],/usr/lib,g' -e 's,[@]fakeroot_transformed[@],'`echo fakeroot | sed -e 's,x,x,'`',g' -e 's,[@]faked_transformed[@],'`echo faked | sed -e 's,x,x,'`',g' -e 's,[@]signal[@],TERM,g' -e 's,[@]SHELL[@],/bin/bash,g' -e 's,[@]VERSION[@],1.11.4,g' -e 's,[@]DLSUFFIX[@],.so,g' -e 's,[@]LDLIBPATHVAR[@],LD_LIBRARY_PATH,g' -e 's,[@]LDPRELOADVAR[@],LD_PRELOAD,g' -e 's,[@]LDPRELOADABS[@],0,g' -e 's,[@]LDEXTRAVAR[@],,g' < ./fakeroot.in > fakeroot
chmod +x fakeroot
make[3]: Verlasse Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4/scripts'
Making all in test
make[3]: Betrete Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4/test'
make[3]: Für das Ziel »all« ist nichts zu tun.
make[3]: Verlasse Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4/test'
make[3]: Betrete Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4'
awk -f ./wrapawk < ./wrapfunc.inp
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c -o communicate.lo communicate.c
gcc -DHAVE_CONFIG_H -I. -O3 -Wall -MT faked.o -MD -MP -MF .deps/faked.Tpo -c -o faked.o faked.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c communicate.c -fPIC -DPIC -o .libs/communicate.o
faked.c: In Funktion »process_chmod«:
faked.c:677: Warnung: format »%lo« erwartet Typ »long unsigned int«, aber Argument 3 hat Typ »fake_mode_t«
faked.c:677: Warnung: format »%lo« erwartet Typ »long unsigned int«, aber Argument 4 hat Typ »fake_mode_t«
libtool: compile: gcc -DHAVE_CONFIG_H -I. -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c communicate.c -o communicate.o >/dev/null 2>&1
mv -f .deps/communicate.Tpo .deps/communicate.Plo
gcc -DHAVE_CONFIG_H -I. -O3 -Wall -MT simple.o -MD -MP -MF .deps/simple.Tpo -c -o simple.o simple.c
mv -f .deps/simple.Tpo .deps/simple.Po
/bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c -o libfakeroot.lo libfakeroot.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c libfakeroot.c -fPIC -DPIC -o .libs/libfakeroot.o
mv -f .deps/faked.Tpo .deps/faked.Po
/bin/bash ./libtool --tag=CC --mode=link gcc -O3 -Wall -o libcommunicate.la communicate.lo -ldl
libtool: link: ar cru .libs/libcommunicate.a .libs/communicate.o
libtool: link: ranlib .libs/libcommunicate.a
libtool: link: ( cd ".libs" && rm -f "libcommunicate.la" && ln -s "../libcommunicate.la" "libcommunicate.la" )
/bin/bash ./libtool --tag=CC --mode=link gcc -O3 -Wall -o simple simple.o -ldl
libtool: link: gcc -O3 -Wall -o simple simple.o -ldl
/bin/bash ./libtool --tag=CC --mode=link gcc -O3 -Wall -o faked faked.o libcommunicate.la -ldl
libtool: link: gcc -O3 -Wall -o faked faked.o ./.libs/libcommunicate.a -ldl
libtool: compile: gcc -DHAVE_CONFIG_H -I. -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c libfakeroot.c -o libfakeroot.o >/dev/null 2>&1
mv -f .deps/libfakeroot.Tpo .deps/libfakeroot.Plo
/bin/bash ./libtool --tag=CC --mode=link gcc -O3 -Wall -release 0 -o libfakeroot.la -rpath /usr/lib libfakeroot.lo libcommunicate.la -ldl
libtool: link: gcc -shared .libs/libfakeroot.o -Wl,--whole-archive ./.libs/libcommunicate.a -Wl,--no-whole-archive -ldl -Wl,-soname -Wl,libfakeroot-0.so -o .libs/libfakeroot-0.so
libtool: link: (cd ".libs" && rm -f "libfakeroot.so" && ln -s "libfakeroot-0.so" "libfakeroot.so")
libtool: link: (cd .libs/libfakeroot.lax/libcommunicate.a && ar x "/home/frschorer/temp/freetz-trunk/source/fakeroot-1.11.4/./.libs/libcommunicate.a")
libtool: link: ar cru .libs/libfakeroot.a libfakeroot.o .libs/libfakeroot.lax/libcommunicate.a/communicate.o
libtool: link: ranlib .libs/libfakeroot.a
libtool: link: rm -fr .libs/libfakeroot.lax
libtool: link: ( cd ".libs" && rm -f "libfakeroot.la" && ln -s "../libfakeroot.la" "libfakeroot.la" )
make[3]: Verlasse Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4'
make[2]: Verlasse Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4'
make[1]: Verlasse Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4'
make -j2 DESTDIR=/home/frschorer/temp/freetz-trunk/tools -C source/fakeroot-1.11.4 install
Making install in scripts
make[2]: Betrete Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4/scripts'
make[3]: Für das Ziel »install-data-am« ist nichts zu tun.
test -z "/usr/bin" || /bin/mkdir -p "/home/user/temp/freetz-trunk/tools/usr/bin"
/usr/bin/install -c 'fakeroot' '/home/user/temp/freetz-trunk/tools/usr/bin/fakeroot'
make[2]: Verlasse Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4/scripts'
Making install in test
make[2]: Betrete Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4/test'
make[3]: Für das Ziel »install-exec-am« ist nichts zu tun.
make[2]: Verlasse Verzeichnis '/home/user/temp/freetz-trunk/source/fakeroot-1.11.4/test'
CONFIG_FILES= CONFIG_HEADERS= /bin/sh ./config.status
test -z "/usr/lib" || /bin/mkdir -p "/home/user/temp/freetz-trunk/tools/usr/lib"
/bin/bash ./libtool --mode=install /usr/bin/install -c 'libfakeroot.la' '/home/user/temp/freetz-trunk/tools/usr/lib/libfakeroot.la'
libtool: install: /usr/bin/install -c .libs/libfakeroot-0.so /home/user/temp/freetz-trunk/tools/usr/lib/libfakeroot-0.so
libtool: install: (cd /home/user/temp/freetz-trunk/tools/usr/lib && { ln -s -f libfakeroot-0.so libfakeroot.so || { rm -f libfakeroot.so && ln -s libfakeroot-0.so libfakeroot.so; }; })
libtool: install: /usr/bin/install -c .libs/libfakeroot.lai /home/user/temp/freetz-trunk/tools/usr/lib/libfakeroot.la
libtool: install: /usr/bin/install -c .libs/libfakeroot.a /home/user/temp/freetz-trunk/tools/usr/lib/libfakeroot.a
libtool: install: chmod 644 /home/user/temp/freetz-trunk/tools/usr/lib/libfakeroot.a
libtool: install: ranlib /home/user/temp/freetz-trunk/tools/usr/lib/libfakeroot.a
libtool: install: warning: remember to run `libtool --finish /usr/lib'
/bin/bash ./libtool --mode=install /usr/bin/install -c 'faked' '/home/user/temp/freetz-trunk/tools/usr/bin/faked'
libtool: install: /usr/bin/install -c faked /home/user/temp/freetz-trunk/tools/usr/bin/faked
sed -i -e 's,^PREFIX=.*,PREFIX=/home/user/temp/freetz-trunk/tools/usr,g' tools/usr/bin/fakeroot
sed -i -e 's,^BINDIR=.*,BINDIR=/home/user/temp/freetz-trunk/tools/usr/bin,g' tools/usr/bin/fakeroot
sed -i -e 's,^PATHS=.*,PATHS=/home/user/temp/freetz-trunk/tools/usr/lib,g' tools/usr/bin/fakeroot
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking filesystem image
3110 inodes (3273 blocks) to write
/home/frschorer/temp/freetz-trunk/./tools/usr/bin/fakeroot: line 178: 29421 Aborted FAKEROOTKEY=$FAKEROOTKEY LD_LIBRARY_PATH="$PATHS" LD_PRELOAD="$LIB" "$@"
ERROR: modunsqfs: Error in build/original/kernel/kernelsquashfs.raw
make: *** [firmware-nocompile] Fehler 1
