make ignoriert .config ?
robinio_1337
25 Mai 2008
ich hab folgendes Problem.
Ich hab freetz-trunk mit verschiedenen Packeten ausgewählt. Problem war dann das ich bei der 7270 probleme mit den DECT-Telefonen hatte. Diese konnten sich zwar anmelden, aber sonst blieben sie ohne Funktion. Auch der Klingeltest zeigte keine Reaktion. Habe dann nach und nach die Patches wieder deaktiviert. Dabei ist mir folgendes aufgefallen.
make_ausgabe:
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking filesystem image
  created 2767 files
  created 122 directories
  created 242 symlinks
  created 159 devices
  created 0 fifos
unpacking var.tar
done.
STEP 2: MODIFY
applying patches
  applying patches (7270-de)
    applying patch file ./patches/7270/100-webif.sh
  Applying symlinks, deleting additional webinterfaces
    applying patch file ./patches/7270/200-modules_symlink.sh
  making symlink for modules (-ur8)
    applying patch file ./patches/100-profile.patch
    patching file etc/profile
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/120-inittab_console.patch
    patching file etc/inittab
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7270/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7270/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    applying patch file ./patches/7270/120-rc.S-dev.patch
    applying patch file ./patches/7270/130-rc.S-logging.patch
    applying patch file ./patches/7270/140-rc.S-no_avm_exit.patch
    applying patch file ./patches/7270/290-replace_websrv-remove_igdd.patch
    applying patch file ./patches/7270/301-remove_smbd.patch
    applying patch file ./patches/7270/400_remove_ftpd.patch
    patching file etc/hotplug/storage
    applying patch file ./patches/7270/de/130-foncalls.patch
    patching file usr/www/all/html/de/home/foncalls.js
    applying patch file ./patches/7270/de/190-webmenu.patch
    patching file usr/www/all/html/de/menus/menu2_homehome.html
    patching file usr/www/all/html/de/menus/menu2.inc
    patching file usr/www/all/html/de/menus/menu2_konfig.html
    applying patch file ./patches/7270/de/200-sperre1.patch
    patching file usr/www/all/html/de/fon/sperre1.js
  creating symlinks /tmp, /mod and /home
  setting subversion 'freetz-devel-2555'
    applying patch file ./patches/100-getcons.sh
  removing /bin/getcons
    applying patch file ./patches/100-profile_term_password.sh
    applying patch file ./patches/100-rename_ctlmgr.sh
    applying patch file ./patches/100-w701v_7170.sh
    applying patch file ./patches/100-w900v_7170.sh
    applying patch file ./patches/110-uclibc.sh
    applying patch file ./patches/140-tr069_cfg.sh
  patching tr069.cfg
    applying patch file ./patches/150-iptables.sh
    applying patch file ./patches/170-rename_ar7login.sh
  renaming ar7login to make way for wrapper script
    applying patch file ./patches/180-printk.sh
  applying printk patch
    applying patch file ./patches/191-webmenu_wol.sh
    applying patch file ./patches/195-webmenu_signed.sh
    applying patch file ./patches/196-usbstorage.sh
  applying USB storage patch
    applying patch file ./patches/cond/usbstorage_7270.patch
    patching file etc/hotplug/run_mount
    applying patch file ./patches/210-ata.sh
    applying patch file ./patches/210-enum.sh
    applying patch file ./patches/210-international.sh
    applying patch file ./patches/220-assistant.sh
    applying patch file ./patches/220-cdrom-iso.sh
    applying patch file ./patches/220-help.sh
    applying patch file ./patches/230-openssl.sh
    applying patch file ./patches/240-add-dsl-expert-pages.sh
    applying patch file ./patches/260-remove_tr069.sh
  removing tr069 stuff
    build/modified/filesystem/usr/share/ctlmgr/libtr069.so
    applying patch file ./patches/270-remove_usb_module.sh
    applying patch file ./patches/290-replace_websrv-remove_igdd.sh
    applying patch file ./patches/300-remove-smbd.sh
    applying patch file ./patches/310-remove_userman.sh
    applying patch file ./patches/320-remove_capiotcp.sh
    applying patch file ./patches/320-remove-dsld.sh
    applying patch file ./patches/330-remove-voip-isdn.sh
    applying patch file ./patches/340-remove_dect_update.sh
    applying patch file ./patches/350-remove_annex_file.sh
    applying patch file ./patches/401-remove_ftpd.sh
    applying patch file ./patches/440-cutdown_samba_control.sh
    applying patch file ./patches/450-autorun_autoend.sh
    applying patch file ./patches/500-remove-mediasrv.sh
    applying patch file ./patches/510-remove_aura_usb.sh
    applying patch file ./patches/510-remove_avm_vpn.sh
    applying patch file ./patches/510-remove_minid.sh
[COLOR="Red"]    applying patch file ./patches/520-remove_dect.sh[/COLOR]
  removing oem: none
installing mod base
  copying files
  installing libs
    libnsl-0.9.28.so
    libcrypt-0.9.28.so
    libgcc_s.so.1
    libdl-0.9.28.so
    libm-0.9.28.so
    libpthread-0.9.28.so
    ld-uClibc-0.9.28.so
    librt-0.9.28.so
    libuClibc-0.9.28.so
replacing busybox
  replacing busybox-8mb_26
  installing symlinks
  installing modules
    fuse.ko
    ext3.ko
    mbcache.ko
    fuse.ko
    ext2.ko
    jbd.ko
  generating modules.dep
installing packages
  fstyp-0.1
  haserl-0.9.24
  modcgi-0.2
  ntfs-1.2812
invoking custom script
done.
STEP 3: PACK
  Checking for left over Subversion directories
squashfs blocksize
  root filesystem: 65536
packing var.tar
creating filesystem image
merging kernel image
  kernel image size: 7511808 (max: 7798784, free: 286976)
packing 7270_04.58freetz-devel-2555.de_20080916-225604.image
done.
FINISHED
.config-File
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_12043=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
FREETZ_TYPE_FON_WLAN_7270=y
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_SPEEDPORT_W701V is not set
# FREETZ_TYPE_CUSTOM is not set
# FREETZ_TYPE_FON_WLAN_7270_16MB is not set
# FREETZ_TYPE_LABOR is not set
FREETZ_AVM_VERSION_STRING="12043"
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_A_CH is not set
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_LANG_STRING="de"
FREETZ_TYPE_STRING="7270"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
# FREETZ_SHOW_ADVANCED is not set
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_KERNEL_MTD_SIZE=119
FREETZ_HAS_PHONE=y
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
# Branding
FREETZ_BRANDING_1und1=y
FREETZ_BRANDING_avm=y
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
# FREETZ_REMOVE_HELP is not set
FREETZ_REMOVE_TR069=y
# FREETZ_PATCH_ENUM is not set
# FREETZ_PATCH_SIGNED is not set
FREETZ_PATCH_USBSTORAGE=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT2=y
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTORUN_AUTOEND is not set
# FREETZ_PATCH_GETCONS is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_USERMAN is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_ANNEX_A_FIRMWARE is not set
# FREETZ_REMOVE_ANNEX_B_FIRMWARE is not set
# Package selection
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
FREETZ_PACKAGE_NTFS=y
# FREETZ_PACKAGE_OPENNTPD is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# Web interface
# FREETZ_PACKAGE_AVM_FIREWALL is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
# FREETZ_PACKAGE_SYSLOGD_CGI is not set
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_GROUP_APACHE_PHP is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# Unstable--------------------------------
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_IPTABLES is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_SITE="ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270/firmware/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270.54.04.58.image"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_SUBVERSION_STRING=y
FREETZ_DEVELOPER_VERSION_STRING=y
# External
# EXTERNAL_ENABLED is not set
# packages
# services
# libraries
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_INETD is not set
# FREETZ_BUSYBOX_PATCH is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_TAC is not set
# FREETZ_BUSYBOX_MDEV_RENAME is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
# Kernel modules
# crypto
# FREETZ_MODULE_crypto_algapi is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_blkcipher is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_cryptomgr is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
FREETZ_MODULE_ext3=y
FREETZ_MODULE_ext2=y
# FREETZ_MODULE_fat is not set
FREETZ_MODULE_fuse=y
FREETZ_MODULE_jbd=y
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
FREETZ_MODULE_mbcache=y
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# FREETZ_STRIP_LIBRARIES is not set
# Libraries -------------------------------
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
# FREETZ_LIB_libcrypto is not set
# FREETZ_LIB_libssl is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
# FREETZ_LIB_libresolv is not set
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# FREETZ_LIB_libuClibcxx is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libglib is not set
# GLib2
# FREETZ_LIB_libglib2 is not set
# FREETZ_LIB_libgobject2 is not set
# FREETZ_LIB_libgmodule2 is not set
# FREETZ_LIB_libgthread2 is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_LIB_libterminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# FREETZ_LIB_libcapi20 is not set
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libpcap is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_HOSTCC="gcc"
FREETZ_KERNEL_VERSION_2_6_19_2=y
FREETZ_KERNEL_VERSION="2.6.19.2"
FREETZ_TARGET_UCLIBC_VERSION_0_9_28=y
# FREETZ_TARGET_UCLIBC_VERSION_0_9_29 is not set
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_UCLIBC_VERSION="0.9.28"
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
ist das so wirklich okay ?
wenn ja hat noch jemand einen Tipp für mich was ich probieren könnte ?
WEnn ich eine orginal FW benutze dann geht alles.
schönen Gruß
robino
Das passt schon so. Die Patches werden alle aufgerufen, aber nur die ausgewählten werden ausgeführt.
Hast du mal den Output von "ps" und "lsmod"?
MfG Oliver
hab heut nochmal das aktuelle trunk ausgecheckt, leider immer noch ohne verbesserung ( hätte ja sein können )
hier die aktuelle config
FREETZ_HAS_PHONE=y
FREETZ_HAS_WLAN=y
# Branding
FREETZ_LANG_DE=y
# Patches
FREETZ_REMOVE_HELP=y
FREETZ_REMOVE_ANNEX_B_FIRMWARE=y
# Package selection
# Standard packages
# Web interface
# Debug helpers
# Testing
# Advanced options
# External
# packages
# services
# libraries
# BusyBox options
# Kernel modules
# crypto
# drivers
# FREETZ_MODULE_musb_hdrc is not set
# fs
FREETZ_MODULE_jbd=y
# lib
# net
# Shared libraries
# Crypto & SSL
# Data compression
# Graphics & fonts
# uClibc
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_librt=y
# GLib2
# ncurses
# terminfo database
# Readline
# Compiler options
FREETZ_JLEVEL=2
FREETZ_HOSTCC="gcc"
FREETZ_TARGET_GXX=y
FREETZ_TARGET_LFS=y
ps liefert dieses ergebniss
/var/mod/root # ps
  PID USER       VSZ STAT COMMAND
    1 root      1160 S    init
    2 root         0 SWN  [ksoftirqd/0]
    3 root         0 SW   [watchdog/0]
    4 root         0 SW<  [events/0]
    5 root         0 SW<  [khelper]
    6 root         0 SW<  [kthread]
   18 root         0 SW<  [kblockd/0]
   32 root         0 SW   [pdflush]
   33 root         0 SW   [pdflush]
   34 root         0 SW<  [kswapd0]
   35 root         0 SW<  [aio/0]
   71 root         0 SW   [pm_info]
   75 root         0 SW<  [CPMAC]
   79 root         0 SW   [mtdblockd]
  101 root         0 SW   [tffsd_mtd_0]
  264 root         0 SWN  [jffs2_gcd_mtd5]
  286 root         0 SW<  [capi_oslib]
  287 root         0 SW<  [capi_oslib]
  288 root         0 SW   [capitransp]
  298 root         0 SW   [avm_dect_thread]
  315 root         0 SW<  [khubd]
  402 root     10808 S N  /usr/bin/avm/ctlmgr
  492 root     10808 S N  /usr/bin/avm/ctlmgr
  494 root     10808 S N  /usr/bin/avm/ctlmgr
  498 root     10808 S N  /usr/bin/avm/ctlmgr
  575 root      4480 S    hostapd -B /var/tmp/hostapd.conf
  581 root      4952 S    igdd
  586 root      4000 S    multid
  604 root      8556 S    telefon a127.0.0.1
  613 root      7748 S <  voipd
  616 root      3184 S    dect_manager
  617 root      4068 S    pbd
  618 root      4068 S    pbd
  623 root      4068 S    pbd
  626 root       960 S    /bin/run_clock -c /dev/tffs -d
  629 root      4068 S    pbd
  678 root      1156 S    httpd -P /var/run/webcfg.pid -p 81 -c /mod/etc/httpd.
  681 root      1160 S    init
  682 root      4952 S    igdd
  683 root      4952 S    igdd
  684 root      4952 S    igdd
  844 root      1160 S    telnetd -l /sbin/ar7login
  887 root      1176 S    -sh
  926 root      1160 R    ps
und lsmod dieses
/var/mod/root # lsmod
Module                  Size  Used by    Tainted: P
wlan_scan_ap           11095  1
wlan_acl                4478  1
wlan_wep                6711  0
wlan_tkip              14118  2
wlan_ccmp               9491  0
wlan_xauth              1182  0
ath_pci               158604  0
ath_rate_atheros       29493  1 ath_pci
wlan                  247857  9 wlan_scan_ap,wlan_acl,wlan_wep,wlan_tkip,wlan_cc
mp,wlan_xauth,ath_pci,ath_rate_atheros
ath_hal               203744  3 ath_pci,ath_rate_atheros
ath_dfs                24350  1 ath_pci
avm_ath_extensions     28085  3 ath_pci,wlan,ath_hal
kdsldmod              882516  0
musb_hdrc              35988  0
usbcore               126044  2 musb_hdrc
dect_io                21060  2
avm_dect              549025  1 dect_io
capi_codec             93998  0
isdn_fbox_fon5        764452  0
pcmlink               156569  3 avm_dect,capi_codec,isdn_fbox_fon5
jffs2                 115457  1
Piglet_noemif          21607  0
wenn Ihr noch was braucht sagt bescheid.
danke schonmal
sunburstc
