Hello,
i am using a smartnode 1200 (isdn) for outgoing calls on voip with justvoip provider.
When i make a call, the receiver don't see my phone number (privé/privat/unknown).
Under justvoip (betamax group) , i have setted and verified the "caller id" (im my case +41217778899 (not possible to set 0041217778899)).
Please help,
Remi
My smartnode sip config :
The log when calling a phone number (0778765432) :
The sip status :
Edit Guard-X: Please use Code-Tags!
Please help,
Remi
gateway sip GW_SIP_XXX
bind interface IF_IP_WAN router
no shutdown
registrar sip.justvoip.com
user +41217778899
registration-lifetime 300
domain sip.justvoip.com
default-server sip.justvoip.com
authentication sip.justvoip.com MyLogin MyPassword default
192.168.1.241#20:58:01 SIP_SI> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] > Stack: INVITE sip:[email protected]
20:58:01 SIP_SI> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] From: sip:[email protected]
20:58:01 SIP_SI> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] To: sip:[email protected]
20:58:01 SIP_TR> [GW] > Stack: INVITE sip:[email protected] SIP/2.0
20:58:01 SIP_TR> [GW] < Stack: SIP/2.0 401 Unauthorized
20:58:01 SIP_TR> [GW] > Stack: ACK sip:[email protected] SIP/2.0
20:58:01 SIP_SI> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] < Stack: Authentication Reqired: sip.justvoip.com
20:58:01 SIP_SI> [GW GW_SIP_XXX] Using authentication data from user:'MyLogin' on service:'default'
20:58:01 SIP_TR> [GW] < Stack: SIP/2.0 100 Trying
20:58:01 SIP_SI> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] < Stack: 100 Trying
20:58:01 SIP_TR> [GW] < Stack: SIP/2.0 183 Session progress
20:58:01 SIP_SI> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] < Stack: 183 Session progress
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 DP] Using datapath termination 0x0200000f
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 DP] Using VoIP profile:
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Configuring datapath termination: Voice
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Highpass Filter: enabled
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Post Filter: enabled
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Silence Supression: disabled
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Voice Update Frames: disabled
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] DTMF Relay: enabled
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Mute Encoder: enabled
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Modem Transmission mode: None
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax Transmission mode: None
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax Bypass Coder: undefined
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Modem Bypass Coder: undefined
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax Dejitter Max. Delay: 200
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Modem Dejitter Max. Delay: 200
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax Max. Bit Rate: 14400
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax Error Correction Mode: enabled
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax/Data HDLC: enabled
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax Detection Mode: CED-Tone
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax Bypass Method: Default
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Modem Bypass Method: Default
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Fax Volume: -9500
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Configuring datapath termination: Dejitter
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Dejitter Mode: adaptive
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Max. Delay: 60
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Max. Packet Loss: 4
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Shrink Speed: 1
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Grow Step: 1
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Grow Attenuation: 1
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 DP] Peer call-leg changed to state CONNECTED
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 DP] Local Media Address: 192.168.1.241
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 DP] Add termination RTP-00/000f to context 0087f188
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Configuring datapath termination: RTP
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Local Address: 192.168.1.241/4864
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Remote Address: 194.120.0.191/41068
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Codec: G.711 u-law (20 ms)
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Media Type: audio
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Payload: Voice=0, SID=13, NTE-Local=101, NTE-Remote=101, NSE-Local=255, NSE-Remote=255
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] SSRC: 11148056
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] TOS: 0
20:58:01 SIP_DP> [EP IF_SIP_XXX-007fa398/0 AUDIO] Datapath: Change direction to send/receive.
20:58:07 SIP_DP> [EP IF_SIP_XXX-007fa398/0 DP] Peer call-leg changed to state DISCONNECTING
20:58:07 SIP_DP> [EP IF_SIP_XXX-007fa398/0 DP] Subtract termination RTP-00/000f from context 0087f188
20:58:07 SIP_SI> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] > Stack: BYE
20:58:07 SIP_TR> [GW] > Stack: CANCEL sip:[email protected] SIP/2.0
20:58:07 SIP_TR> [GW] < Stack: SIP/2.0 200 Ok
20:58:07 SIP_TR> [GW] < Stack: SIP/2.0 487 Request terminated
20:58:07 SIP_ER> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] < Stack: UNHANDLED STACK EVENT: BASIC STATUS: 200 Ok
20:58:07 SIP_TR> [GW] > Stack: ACK sip:[email protected] SIP/2.0
20:58:07 SIP_SI> [EP IF_SIP_XXX-007fa398 SES 0x7fb880] < Stack: 487 Request terminated
20:58:07 SIP_SI> [EP IF_SIP_XXX-007fa398] Finished
SIP Gateway: GW_SIP_XXX
State: Up
User Agent: 0xa7f8a0
Local Address: 192.168.1.241:5060
Registrations
SIP Registration: sip:[email protected] (Service: default)
State: Registered
Registrar: sip:sip.justvoip.com
Default Server: (none)
Logical Address: sip:[email protected]
Physical Address: sip:[email protected]:5060 (Current: sip:[email protected]:5060)
Expiration Time: 300 s
Authenticated: yes
Allocated Endpoints: 0
Allocated Sessions: 0
Allocated Audio Datapath Controllers: 0
Allocated Packets: 1
Max Allocated Packets: 11
Max Allocated Timers: 9
