mein Telefonanbieter hat dieses Leistungsmerkmal für mich freigeschaltet. Leider funktioniert es mit folgender Config nicht. Es wird immer die Haupt-MSN übertragen. Benutzt wird eine AVM Fritz PCI 2.0 mit CAPI-Treiber.
Jetzt weiss ich nicht, ob es am Anbieter oder mir liegt.
extensions.conf
capi.conf
extensions.conf
exten => s,1,Set(CALLERID(num)=00ANDERENUME00)
exten => s,2,NoOp()
exten => s,3,Dial(CAPI/ISDN1/${ARG1}/b)
capi.conf
[general]
nationalprefix=0
internationalprefix=00
rxgain=1.0 ;linear receive gain (1.0 = no change)
txgain=1.0 ;linear transmit gain (1.0 = no change)
language=de ;set default language
;ulaw=yes ;set this, if you live in u-law world instead of a-law
; interface sections ...
[ISDN1] ;this example interface gets name 'ISDN1' and may be any
;name not starting with 'g' or 'contr'.
;Use one interface section for each isdn port!
;ntmode=yes ;if isdn card operates in nt mode, set this to yes
isdnmode=msn ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
;when using NT-mode, 'DID' should be set in any case
incomingmsn=* ;allow incoming calls to this list of MSNs/DIDs, * = any
controller=1 ;capi controller number of this interface/port
group=1 ;dialout group
;prefix=0 ;set a prefix to calling number on incoming calls
softdtmf=off ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=on ;in addition to softdtmf, you can use relaxed dtmf detection
faxdetect=outgoing ;enable faxdetection and redirection to EXTEN 'fax' for incoming and/or
;outgoing calls. (default='off', possible values: 'incoming','outgoing','both')
accountcode= ;PBX accountcode to use in CDRs
;amaflags=default;AMA flags for CDR ('default', 'omit', 'billing', or 'documentation')
context=capi-in ;context for incoming calls
devices=2 ;number of concurrent calls (b-channels) on this controller
