- Mitglied seit
- 30 Jun 2004
- Beiträge
- 12,882
- Punkte für Reaktionen
- 0
- Punkte
- 0
Neue Firmware für das F1000 befindet sich im Downloadbereich des Forums und wird im Laufe des Wochenendes auch über meine Webseiten zum direkten web-basierten Upgrade angeboten.
Wer schon die Firmware 4.30 auf seinem Telefon hat, kann sich das Update sparen. Die 4.30 und die 4.50 sind bis auf die Versionsnummer identisch. 4.30 war nur die BETA Version vor der offiziellen Veröffentlichung und 4.50 ist nun die OFFICIAL
xRelease Notes F/W 4.50st
Incoming RTP port: F1000 didn't accept RTP message from other end it its originating RTP port did not match negotiated RTP port. This restriction is removed in this version and handset doesn't check if originationg port of incoming RTP messages matches negotiated port in SDP
WPA enabled AP connectivity: Sometimes handset could not connect to the AP which had WPA security turned ON and SSID broadcast disabled. This issue is fixed in this version
WPA key hiding: Access ti WPA key in SSID profile configuration is enabled only after entering user code. This restriction is added to prevent WPA key accessby unaothorized person through handset menu, which could be used to access Enterprise or user WLAN network
Dynamic payload type for telephone event in SDP: Apart from 100 and 101, F1000 should accept any payload type selected by SIP server
SIP 302: Redirect/Moved temporarily message is supported
Removing eZi mode: eZi predictive text input option is removed from Address book and other configuration menus since it is not used.
Block F1000G firmware download: This version blocks downloading F1000G firmware into F1000 handset. Due to this modification, F1000 handset can not be downgraded using remote or local firmware upload methods below 4.50st firmware version. Even in the future firmware versions, handset can be downgraded to firmware version up to 4.50st but not below 4.50st version.
Close the telnet port: Access to telnet port is disabled
Display SIP Username on main display: Add a menu in "Settings -> Scheme" level for users to enable or disable the main display to show SIP username
Version No in SIP UA: F1000 version number is added to SIP Useragent field in all the SIP messages from F1000
"Allow" field in SIP messages: "Allow" field is added in SIP INVITE and other messages
