brctl for fbf?
arnevt
29 Mrz 2006
Hi
I've installed openvpn on the FBF 7050. Instead of using the tun device, I wish to use a tap device, and put in bridging with the lan interface. Now I only get as far as using proxy_arp, which solves 90% of my needs, but I really would love to have some sort of brctl in the fritzbox... has somebody a binary for that? Of does the kernel by default not support bridge-utils?
thx
Arne
Hi.
I've compiled bridge-utils for you. But I'm not sure if this is what you want?
Greets, Oliver
  • bridge-utils.tar.gz
ik the kernel has bridging support en those binaries will work (compiled for FBF) that's exactly what I needed :)
curious2315
