Gigaset C470 IP, C475 IP, S675 IP, S685 IP - Firmware V02214 von 11/2009
fkoehn
20 Nov 2006
Funktioniert prima - endlich kann ich meine aus Google Contacts exportierten CSV Adressen sauber hochladen.
GENIAL!
http://gigaset.com/shc/0,1935,hq_en...Type%3Adownloads_imagePos%3A0,00.html#content
Readme
Gigaset C470 IP, C475 IP, S675 IP and S685 IP
Firmware Update 11/2009 Version V02214:
New features:
- VoIP: Call transfer also possible for incoming calls.*
- VoIP: Performs audio codec negotiation up- and downwards during a call.
- VoIP: Acoustic signalling of received out-of-band DTMF-tones during a call.
- Web Configurator: new languages - Spanish and Brazilian Portuguese. English is preinstalled. The rest of the available languages will be downloaded when they are selected.
- Web Configurator (Settings/Telephony/Number Assignment): Enhanced Auto-Fallback implemented. If the call via IP fails, the phone will automatically dial via next active IP account, trying all IP accounts one by one.***
- Web Configurator (Settings/Telephony/Number Assignment): Support of a web-based "Call Manager" for incoming and outgoing calls. Works under the premise: IP provider runs a BroadSoft-system.*
- Web Configurator (Settings/TelephonyAdvanced Settings): Auto DTMF negotiation implemented.
- Web Configurator (Settings/Security): Transport Layer Security (TLS) for Gigaset auto-configuration and TR-069 implemented.*/**
- Switzerland: Free VoIP calls between Gigaset IP phones via Phonet.ch. If the entry Phonet.ch is not in the directory, the handset has to be re-registered at the base station.
Provider relevant features:
- SIP over TCP: The prefered transport protocol (UDP/TCP) can be set via the provider profile.
- Period for the automatic check of provider settings is configurable via the provider profile.
- Web Configurator (Settings/IP Configuration): VLAN-Tagging for virtual networks implemented.*/**
- TR-069: Support of Auto-Configuration Server (ACS): Alcatel/Lucent and Gigaset Software Suite.
- Interoperability with softswitches: Asterisk (V 1.4.18), Broadsoft (R14SP5), IP Centrex, Sylantro AS (V4.1.1), Nortel CS2K.
Improvements:
- Enhanced reliability of Gigaset.net service through implementation of a RTP-Proxy.
- Web Configurator: Support of Internet Explorer 8.0 and Mozilla Firefox 3.5 (with MS Vista) improved.
- Telephonebook down-/upload via Web Configurator: vCards are now uploaded correctly.
- Improved behaviour during conference calls.*
- Automatic check for firmware and provider profile updates improved.
- SMS via IP: reception of linked SMS improved.*
- CLIP for Brazil, Russia, Netherlands, Great Britain: error correction.
- Correction of Russian display texts.
- Handling of audio codec G729 improved.
- VoIP: support of "0+<Number>" format for incoming calls (CLIP).*
Known Bugs:
- Web Configurator (Settings/Services): incorrect provider names in the online-directory list. The functionality is not affected by that.
V02214 correct
AT - Norway => AT - Herold
CH - Panama => CH - [tel.search.ch]
DE - Mexico => DE - klickTel
DK - New Zealand => DK - De Gule Sider
NL - Morocco => NL - De Telefoongids
NO - Netherlands => NO - Gule Sider
Hey, kein Thema - ich sehe zukuenftig gerne von Postings ab. Wir wollen ja keine Bytes verschwenden...
Es geht nur darum zu vermeiden, daß sich mehrere Threads zum selben Thema entwickeln.
Hi! Ist bekannt, ob man dies Update auch problemlos fuer die "Sinus 501V von T-Home nutzen kann. Die soll ja angeblich baugleich sein.
Bei der Frage gehe ich davon aus, dass das Firmware Update fuer die Basis ist, nicht fuer das Mobilteil. Oder fuer beides?
Gruss
Jowi
Schau doch mal im T-Com -> Siemens OEM Forenbereich vorbei, da findest du mehr Infos.
Bei T-Com bin ich nicht fündig geworden, aber hier im Forum:
Nun antworte ich mir mal selber, falls noch jemand diese Frage haben sollte:
Es gibt in diesem Forum eine tolle Anleitung, wie man das T-Com Sinus zu einem Gigaset S685IP umfunktionieren kann, dann kann man bei Gigaset die Updates nutzen.
Für diese Anleitung vielen Dank!
Hallo Jowik,
vielleicht solltest Du noch mal ganz genau lesen, was neffs am 05.03. um 10:35 Uhr geschrieben hat (das Posting vor Deinem Beitrag).
Und gegen einen Link wie: Anleitung Sinus 501V -> S685 IP hat in diesem Forum auch noch nie jemand was gehabt.
Viele Grüße,
Jirka
