Die Befehle für die LEDs der Fritz Box
Dino75195
3 Jan 2005
könnt mir noch jeman sagen, wie man die verschiedenen LEDs der Fritz Box an, bzw ausschaltet.
der Befehl für die Power Lampe ist 1,4/var/led
gibt es da eine bestimmte Logig?
anscheinend wurde das auch schon in verschiedenen Versionen anders angesteuert.
schönen Tag noch :shock:
mfg Robert
cat /etc/*led.conf
zeigt:
module = adsl, 0 : 1, adsl    # module = {adsl,usb,pppoe,wlan}
# Note: state 0 for adsl is dummy state and is present only for ##
#       compatibility with the new LED driver                   ##
state   = 0     # 0=dummy, 1=idle, 2=training, 3=sync, 4=activity
gpio    = 7
mode    = 0     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash
state   = 1     # 0=dummy, 1=idle, 2=training, 3=sync, 4=activity
gpio    = 7
mode    = 4     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash
param1  = 250   # flash on duration in ms
param2  = 250   # flash off duration in ms
state   = 2     # 0=dummy, 1=idle, 2=training, 3=sync, 4=activity
gpio    = 7
state   = 3     # 0=dummy, 1=idle, 2=training, 3=sync, 4=activity
gpio    = 7
module = adsl, 1 : 8, power
state   = 0         # 1 = power led off
gpio    = 7
mode    = 1     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash
state   = 1         # 1 = power led on
gpio    = 7
param   = 0     # blink/flash rate in ms
state   = 2         # 1 = power led on
gpio    = 7
param1  = 250   # blink/flash rate in ms
state   = 3         # 1 = power led on
gpio    = 7
param1  = 1000  # blink/flash rate in ms
module = internet, 0 : 14, sip
gpio    = 13
gpio    = 13
gpio    = 13
param2  = 250   # blink/flash rate in ms
gpio    = 13
param2  = 1000  # blink/flash rate in ms
module = internet, 1 : 20, mwi
state   = 0     # led off
gpio    = 13
state   = 1     led on
gpio    = 13
state   = 2     # led blink
gpio    = 13
state   = 3     #
gpio    = 13
param1  = 125   # blink/flash rate in ms
param2  = 125    # blink/flash rate in ms
state   = 4     # blink code0 2
gpio    = 13
mode    = 5     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash 5: Blink-Code0 6: Blink-Code1 7: Blink-Code2
param2  = 1     # blink/flash rate in ms
state   = 5     # blink code0 3
gpio    = 13
param2  = 2     # blink/flash rate in ms
state   = 6     # blink code0 4
gpio    = 13
param2  = 3     # blink/flash rate in ms
state   = 7     # blink code0 2
gpio    = 13
mode    = 6     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash 5: Blink-Code0 6: Blink-Code1 7: Blink-Code2
state   = 8     # blink code0 3
gpio    = 13
state   = 9     # blink code0 4
gpio    = 13
state   = 10     # blink code0 2
gpio    = 13
mode    = 7     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash 5: Blink-Code0 6: Blink-Code1 7: Blink-Code2
state   = 11     # blink code0 3
gpio    = 13
state   = 12     # blink code0 4
gpio    = 13
module = ab, 1 : 13, pots           # 1 = adsl 2 = pppoe  3 = lan 4 = wifi  5 = usb 6 = eth  7 = info  8 = power
gpio    = 12
gpio    = 12
gpio    = 12
gpio    = 12
module = pppoe, 0 : 2, ppp   # module = {adsl,usb,pppoe,wlan}
state   = 0     # 0 = pppoe down, 1 = pppoe active
gpio    = 10
state   = 1     # 0 = pppoe down, 1 = pppoe active
gpio    = 10
gpio    = 10
param1  = 125   # flash on duration in ms
param2  = 125   # flash off duration in ms
module = info, 0 : 7, info   # module = {adsl,usb,pppoe,wlan,info}
state   = 0     # 0 = link down, 1 = link up, 2 = pkt rcv, 3 = pkt xmit
gpio    = 9
state   = 1     # 0 = link down, 1 = link up, 2 = pkt rcv, 3 = pkt xmit
gpio    = 9
state   = 2     # 0 = link down, 1 = link up, 2 = pkt rcv, 3 = pkt xmit
gpio    = 9
state   = 3     # 0 = link down, 1 = link up, 2 = pkt rcv, 3 = pkt xmit
gpio    = 9
module = info, 1 : 18, traffic
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
state   = 4     # blink code 2
gpio    = 9
mode    = 5     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash 5 Blink-Code
state   = 5     # blink code 3
gpio    = 9
state   = 6     # blink code 4
gpio    = 9
param2  = 4     # blink/flash rate in ms
state   = 7     # blink code 5
gpio    = 9
param2  = 5     # blink/flash rate in ms
state   = 8     # blink code 6
gpio    = 9
param2  = 6     # blink/flash rate in ms
state   = 9     # blink code 7
gpio    = 9
param2  = 7     # blink/flash rate in ms
state   = 10    # blink code 8
gpio    = 9
param2  = 8     # blink/flash rate in ms
state   = 11    # blink code 9
gpio    = 9
param2  = 9     # blink/flash rate in ms
state   = 11    # blink code 10
gpio    = 9
param2  = 10    # blink/flash rate in ms
module = info, 2 : 16, freecall
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
gpio    = 9
module = info, 3 : 19, avmusbwlan
gpio    = 9
gpio    = 9
gpio    = 9
param1  = 180   # blink/flash rate in ms
param2  = 180   # blink/flash rate in ms
module = error, 0 : 17, error
state   = 0         # 0 = all leds off
gpio    = 7     # gpio number
mode    = 1     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash 5 Blink-Code
gpio    = 13    # gpio number
mode    = 0     # 0 = off,1 = on,2 = blinkoff,3 = blinkon, 4 = Flash 5 Blink-Code
gpio    = 12    # gpio number
gpio    = 9     # gpio number
gpio    = 10    # gpio number
state   = 1         # 1 = all leds on
# Blink Code 1
state   = 2         # 2 = all leds fast blink
# Blink Code 2
state   = 3         # 3 = all leds slow bink
# Blink Code 3
state   = 4         # 3 = all leds slow bink
# Blink Code 4
state   = 5         # 3 = all leds slow bink
# Blink Code 5
state   = 6         # 3 = all leds slow bink
# Blink Code 6
state   = 7         # 3 = all leds slow bink
# Blink Code 7
state   = 8         # 3 = all leds slow bink
# Blink Code 8
state   = 9         # 3 = all leds slow bink
# Blink Code 9
state   = 10    # 3 = all leds slow bink
# Blink Code 10
state   = 11    # 3 = all leds slow bink
# Blink Code 11
state   = 12    # 3 = all leds slow bink
param2  = 11    # blink/flash rate in ms
# Blink Code 12
state   = 13    # 3 = all leds slow bink
param2  = 12    # blink/flash rate in ms
# Blink Code 13
state   = 14    # 3 = all leds slow bink
param2  = 13    # blink/flash rate in ms
Ich bin nicht ganz sicher, was das alles bedeutet.
Fest steht jedoch für mich:
echo X,Y>/var/led
bewirkt:
X=7,16,18,19 Info-LED
X=2 DSL-LED
X=13 Festnetz-LED
X=14,20 Internet-LED
X=8 Power-LED
X=17 alle LEDs
X=1 ?
Y=1 aus
Y=2 an
Y=3 schnelles Blinken
Y=4 langsames Blinken
oder so ähnlich. Es gibt offensichtlich gewisse Regeln, die definieren, was z.B. passiert, wenn nacheinander 7,3/16,1/17,4 eingegeben wird.
Da steig ich im Moment nicht durch.
Gabs da nicht schon mal einen Thread? [s:38601e568c]Ich find da jetzt grad nix mehr :noidea:[/s:38601e568c]
[edit] Das da meinte ich: http://www.wehavemorefun.de/fritzbox/Ledcfg (Ist leider auch nicht sehr hilfreich) [/edit]
Danke!!!
hab viel gesucht, aber nichts gefunden,
vielleicht sollte man das auf der Fritz Box Homepage eintragen
gruß Robert
hi ich hab da mahl ne frage zu ich wolte was ausprobiren und mir das file umbauen mit folgenden befhelen hab ich versucht ne altanative config zu laden nur selbst das geht eigenartiger weise nicht.
cat /etc/Fritz_Box_FON_ATA.led.conf>/var/tmp/led.conf
danach hab ich denn laufenden prozess beendet mit
ledcfg -s
wenn ich jetzt neu starte mit:
ledcfg -c -d -f /var/tmp/led.conf
geht das nicht ich bekomme dan folgende ausgabeaber gehen tut es dann nicht
# ledcfg -c -d -f /var/tmp/led.conf
[ledcfg]: start led-demon
led_demon started
Edit: jetzt geht es
auch der aufbau der datei ist relativ simpel
z.b. ein test von mir
######## Power LED 8#########
module = adsl, 1 : 8, power Weis ich nicht scheint egahl zu sein
state = 0 (das legt fest welcher status bei X,Y den Y wert fest)
gpio = 7 (Die led die angesteuert wird)
mode = 1 (mode 0= off, 1= on, 2 binken,3=flash)
state = 1
gpio = 7
mode = 4
param1 = 250 (auch klar hier wird festgelegt wie lange die led an sein muss in ms)
param2 = 250 (hier wird festgelegt wie lange die led aus sein muss)
na dann sollte es doch auch machbar sein eine der led's blinken zu lassen so lange wireless an ist *g*
ja reintoretisch leider sind scheinbar irgentwelche verknüpfungen verhanden das z.b. wenn die internet led nicht leuchtet die, beiden leds für die telefonie nicht gehen alerdinks ist in der hinsicht der code leicht merkwürdig hab angefangen mahl eigende files zu schreiben die nach langen testen auch gehen nur wenn die böx dazwischenfunkt und leds anschaltet für die keine regel da ist stürtzt ledcfg ab das erweitern der datei ist komplizirt wenn mann nicht genau weis wie welche regeln genau aufgebaut sind
ich korigire mach mahl so leicht ist das doch net habe aber einige infos gefunden über die software die verwendet wird
Infos: http://soekris.hejl.de/
und vileich die folgende könte hilfreich sein
/proc/avalanche/led_cfg
der Befehl zum Ausschalten der DSL LED funktioniert bei mir nicht. ( echo 2,1>/var/led ) Und wenn ich den Befehl für alle LED's gebe bleibt der Zustand der DSL LED und der Power LED unverändert.
Weiß jemand vielleicht nen anderen Befehl ?
satfreak1987 :)
Auf der Box läuft Folgendes:
die Datei /var/led ist eine FiFo, die von /usr/bin/ledcfg überwacht wird, und dann wird eben das ausgeführt, was in /etc/Fritz_Box_....led.conf konfiguriert ist. ( ps|grep led )
Du kannst ja mal ein bißchen mit dem ledcfg spielen. Doku gibts dazu natürlich keine. Das was ledcfg --help anbietet, ist nicht gerade sehr hilfreich.
Ob es sich wirklich um die von theborg erwähnte Software handelt? Ich weiß nicht. Bei mir steht in /proc/avalanche/led_ver:
TI Linux LED Driver Version 1.0
@theborg: Wo hast Du denn die Information her?
So, nach ausgiebigem Experimentieren habe ich nun folgendes herausgefunden:
Der Aufbau der /etc/*led.conf (bei der 7050) ist folgender:
module = irgendwas, irgendwas : X, Bezeichnung
state = Y-1 (!!!) # Der Kommentar ist manchmal unbrauchbar (offenbar durch copy&paste entstanden)
gpi0 = Nummer der LED # 7 = mehrere LEDs(?), 9 = Info, 10 = DSL, 12 = Festnetz, 13 = Internet
mode = An-/Aus-/Blinkmodus # Erklärung steht dahinter
param1 = i
param2 = j
X und Y beziehen sich auf den Befehl
echo X,Y>/var/led
Die Werte param1 und param2 haben unterschiedliche Bedeutungen, je nach mode.
param2 kann für die Häufigkeit des Blinkens oder für die Dauer des Erlöschens stehen.
Offensichtlich hat auch gpi0 = 7 verschiedene Auswirkungen, so wird z.B. mit X=8 die Power-LED angesprochen, während bei X=17 alle LEDs betroffen sind.
Das Blinked der LEDs kann unter Umständen überlagert werden, also führt z.B. der Befehl
echo 17,6 > /var/led
nicht zwangsläufig dazu, dass alle LEDs kontinuierlich 4x blinken, sondern nur diejenigen, die nicht an sind.
Aus diesem Grund funktioniert X=8 nur, wenn zuvor mit 1,1 die Power-LED ausgeschaltet wurde.
Sie ist sozusagen doppelt an (1x mit X=8 und 1x mit X=1), oder so ähnlich :mrgreen:
Hier gilt es noch, genauere Nachforschungen anzustellen.
Dazu existiert mittlerweile dieser Thread.
Richtig gut (und für so manchen sinnvoll) würde es allerdings erst, wenn man auch verschiedene Farben der wenigen LEDs ansteuern könnte. Aber dazu wären u. A. (aber nicht nur) andere LEDs erforderlich.
Träume . . . . :habenwol:
Der (Hardware-)Mod wurde sogar auch schon hier beschrieben... :-)
Vermutlich habe ich mich nicht präzise genug ausgedrückt. Ich meine unterschiedliche Farben jeder einzelnen LED. Hardwaremäßig ist das ja kein Problem.
Wenn Du zwei Farben ansteuern willst brauchst Du zwei LEDs, bzw eine Doppel-LED.
Würde heisen, Du fasst Zwei zu Einer zusammen.
Bei einer Doppel-LED hättest Du noch vier "Lichter",
bei zwei nur noch drei "Lichter"; der Rest bleibt dunkel.
Oder Du müsstest eine andere Hardware-steuerung verwenden.
Wie währes es mit ein paar ICs am internen serialen Port eine zusätzliche LED-Steuerung zu bauen?
Dann kannst Du bald die Fritz!box komplett selbst herstellen :lol:
Hast Du noch nie von einer LED gehört, die alle Farben abstrahlen kann? Jahre alte Technologie! :alt:
Die strahlt dann weißes Licht ab und heißt Glühbirne? ;)
Ach wichard, Du wirst doch nicht wirklich sooo rückständig sein, wie Du tust?!
Glühlampen, (Glühbirnen gibt es überhaupt nicht ) strahlen kein weißes Licht ab!
Ein LED-Chip kann immer nur eine Farbe:
Infrarot (nicht sichtbar)
Rot
Orange (besonders hell)
Gelb
Grün
Blau
Blau mit Leuchtstoffschicht=Weiß
neuerdings auch UltraViloett
Stimmt man kann mehrere in ein Gehäuse setzen.
Braucht trotzdem pro LED-Chip eine Ansteuerung von der Fritzbox.
Die jetzigen FB können 5 LED, egal ob einzeln oder bunt in einen Gehäuse.
RGB-LEDs:
1xRot
1xGrün
2xBlau (wegen der Helligkeit)
Zum Farbenmischen braucht man Stromquellen oder
Pulsweitenmodulation (bliken mit einigen kHz)
Viel Spaß beim basteln...
Jaja, ich hätte doch nicht Physik als Studienfach wählen sollen... ;)
Ach, wichard,
wo ist das Problem?
Du weißt doch selbst, daß Glühlampenlicht eine erbärmlich niedrige Temperatur in °Kelvin hat! Also ist es nicht weiß, oder?
Falls ich mich irgendwo irre, klär mich bitte auf. Ich lerne gerne dazu!
nikitarajusa
