[avm_power]event: 27 not handled
00:28:52 connection_by_free - Connection: 0
00:28:52 Ignoring connection for unknown account. CalledParty=unknown, CallingP arty=0#0551*******
[speedup] -> 62.5 MHz
00:28:53 Queue=18, Pending=0
00:28:53 Queue=19, Pending=0
00:28:53 Queue=20, Pending=0
[speedup] -> 125 MHz
00:29:04 Queue=21, Pending=0
00:29:04 Queue=22, Pending=0
00:29:04 Queue=23, Pending=0
00:29:07 connection_by_free - Connection: 0
00:29:07 Ignoring connection for unknown account. CalledParty=10000, CallingPar ty=0#0551*******
00:29:07 RX-REQUEST 1046 bytes Request msg INVITE/cseq=27 (rdata0x5232e4) from UDP 127.0.0.1:5060
00:29:07
INVITE sip:[email protected]:5061 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5060;rport;branch=z9hG4bK6357C0F87A9E6A7E
To: <sip:[email protected]:5061>
Call-ID: [email protected]
CSeq: 27 INVITE
Contact: <sip:*******@127.0.0.1;uniq=AA0E807CA38D1080EFCA2AC72D7AD>
Max-Forwards: 70
Expires: 120
User-Agent: AVM FRITZ!Box Fon WLAN 7170 29.04.93 TAL (Jun 11 2008)
Supported: 100rel,replaces
Allow-Events: telephone-event,refer
Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,PRACK,INFO,SUBSCRIBE,NOTIFY,REFER,ME SSAGE
Content-Type: application/sdp
Accept: application/sdp, multipart/mixed
Accept-Encoding: identity
Content-Length: 351
v=0
o=user 3964202 3964202 IN IP4 127.0.0.1
s=call
c=IN IP4 127.0.0.1
t=0 0
m=audio 7078 RTP/AVP 8 0 2 102 100 99 97 101
a=sendrecv
a=rtpmap:2 G726-32/8000
a=rtpmap:102 G726-32/8000
a=rtpmap:100 G726-40/8000
a=rtpmap:99 G726-24/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-11
a=rtcp:7079
00:29:07 Create UAS dialog ...
00:29:07 Create media capability ...
00:29:07 Create invite session ...
00:29:07 Respond 100 ...
00:29:07 [type=voip/out conid=0 accid=1 src=sip:*******@127.0.0.1 trg=10000@sip gate.de] Call state changed to INCOMING
00:29:07 Respond 180 (*ring*)..
00:29:07 [type=voip/out conid=0 accid=1 src=sip:*******@127.0.0.1 trg=10000@sip gate.de] Call EARLY (reason=0, Default status message)
00:29:07 [type=voip/out conid=0 accid=1 src=sip:*******@127.0.0.1 trg=10000@sip gate.de] Incoming DTMF (1)
00:29:07 [type=voip/out conid=0 accid=1 src=sip:*******@127.0.0.1 trg=10000@sip gate.de] Incoming DTMF (0)
00:29:07 connection_by_free - Connection: 1
00:29:07 [plugin.menu] Action: script:action_wrapper (acc=1 con=0)
00:29:07 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "CONNECT", "USER", "OUTGOING", "0", "-1", "0551*******", "10000@sip gate.de", "1", "", "") (acc=1 con=0)
00:29:07 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "DDI", "USER", "OUTGOING", "0", "-1", "0551*******", "10000@sipgate .de", "1", "", "1") (acc=1 con=0)
00:29:08 [plugin.menu] Action: script:action_wrapper (acc=1 con=0)
00:29:08 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "DDI", "USER", "OUTGOING", "0", "-1", "0551*******", "10000@sipgate .de", "1", "", "0") (acc=1 con=0)
00:29:09 [plugin.menu] Action: script:action_wrapper (acc=1 con=0)
00:29:09 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "DDI", "USER", "OUTGOING", "0", "-1", "0551*******", "10000@sipgate .de", "1", "", "0") (acc=1 con=0)
00:29:09 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "EARLY", "USER", "OUTGOING", "0", "-1", "0551*******", "10000@sipga te.de", "1", "", "") (acc=1 con=0)
May 15 00:29:10 voipd[494]: rtp_dgramrcv: packet from 127.0.0.1 ignored, should be from 67.63.50.48
00:29:09 Set high priority
00:29:09 connection_by_free - Connection: 1
00:29:09 Make VoIP call by client (<sip:*******@67.63.50.48:5061;uniq=AA0E807CA 38D1080EFCA2AC72D7AD> -> <sip:[email protected]>) ...
00:29:09 Initialize outgoing call from '<sip:*******@67.63.50.48:5061;uniq=AA0E 807CA38D1080EFCA2AC72D7AD>' to '<sip:[email protected]>'
00:29:09 Create SDP ...
00:29:09 Create invite session ...
00:29:09 [type=voip/out conid=1 accid=1 src=<sip:*******@67.63.50.48:5061;uniq= AA0E807CA38D1080EFCA2AC72D7AD> trg=<sip:[email protected]>] Call state changed to CALLING
00:29:09 [plugin.menu] Action: script:action_wrapper (acc=1 con=1)
00:29:09 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "CONNECT", "VOIP", "OUTGOING", "1", "0", "0551*******", "10000@sipg ate.de", "1", "", "") (acc=1 con=1)
00:29:10 [type=voip/out conid=1 accid=1 src=<sip:*******@67.63.50.48:5061;uniq= AA0E807CA38D1080EFCA2AC72D7AD> trg=<sip:[email protected]>] Call state changed to CALLING
00:29:10 [type=voip/out conid=1 accid=1 src=<sip:*******@67.63.50.48:5061;uniq= AA0E807CA38D1080EFCA2AC72D7AD> trg=<sip:[email protected]>] Call CONNECTING (reas on=0, Default status message)
00:29:10 On media update
00:29:10 stream #0: PCMA (8000/1)
00:29:10 stream #0: disable VAD [port=1]
00:29:10 Encoder stream started
00:29:10 Decoder stream started
00:29:10 [type=voip/out conid=1 accid=1 src=<sip:*******@67.63.50.48:5061;uniq= AA0E807CA38D1080EFCA2AC72D7AD> trg=<sip:[email protected]>] Call CONFIRMED (reaso n=0, Default status message)
00:29:10 Respond stateless with code 200
00:29:10 stream #0: disable VAD [port=0]
00:29:10 Port 3 (voip port [0]) transmitting to port 1 (voip port [1])
00:29:10 Port 1 (voip port [1]) transmitting to port 3 (voip port [0])
00:29:10 [type=voip/out conid=0 accid=1 src=sip:*******@127.0.0.1 trg=10000@sip gate.de] Call CONNECTING (reason=0, Default status message)
00:29:10 [plugin.menu] Action: script:action_wrapper (acc=1 con=1)
00:29:10 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "CONFIRMED", "VOIP", "OUTGOING", "1", "0", "0551*******", "10000@si pgate.de", "1", "", "") (acc=1 con=1)
00:29:15 Queue=24, Pending=0
00:29:15 Queue=25, Pending=0
00:29:15 Queue=26, Pending=0
00:29:26 Queue=27, Pending=0
00:29:26 Queue=28, Pending=0
00:29:26 Queue=29, Pending=0
[00121399]DSP: XDU=1( S1 ) OVR=0 MIPS_OVR=0
00:29:34 [type=voip/out conid=1 accid=1 src=<sip:*******@67.63.50.48:5061;uniq= AA0E807CA38D1080EFCA2AC72D7AD> trg=<sip:[email protected]>] Call DISCONNECTED (re ason=200, OK)
00:29:34 Port 3 (voip port [0]) stop transmitting to port 1 (voip port [1])
00:29:34 Port 1 (voip port [1]) stop transmitting to port 3 (voip port [0])
00:29:34 VoIP client disconnected [0]
00:29:34 [plugin.menu] Action: script:action_wrapper (acc=1 con=0)
00:29:34 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "DISCONNECT", "USER", "OUTGOING", "0", "-1", "0551*******", "10000@ sipgate.de", "1", "", "0") (acc=1 con=0)
00:29:34 [type=voip/out conid=0 accid=1 src=sip:*******@127.0.0.1 trg=10000@sip gate.de] Call DISCONNECTED (reason=603, Decline)
00:29:34 [plugin.menu] Action: script:action_wrapper (acc=1 con=1)
00:29:34 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/scrip t/action.sh, "DISCONNECT", "VOIP", "OUTGOING", "1", "-1", "0551*******", "10000@ sipgate.de", "1", "", "200") (acc=1 con=1)
00:29:34 Set low priority
